rummy »
https://forums.nicoclub.com/rummy-u222376.html
Tue Jul 09, 2013 5:31 am
Thanks Rev D21.. Does this mean the transmission is scrap or do you believe it can be looked at and possibly fixed. I must pull the transmission to either replace or repair, but can you or anyone else tell me if there is a way to determine if there is linkage damage or bad synchronizes and is it possible or feasible to try and replace syncros or damaged shift linkage?? Also, do you D21 or anyone else know if an older nissan or datsun 4 speed transmission may bolt up to my engine and work???? I have access to a 4 speed that came out of an early model Datsun Z car that is perfect. Can this be used in my 98 Nissan pickup?? Thanks so much!!
