1998 I30 Won't Crank
broc5k
Hello, been a while since I've came around :biggrin: Searched and couldn't find anything. So lately I've been having to drive my roomates 1998 I30, and last night it wouldn't start. I turn the key, all lights come on, I hear a click below my left knee (I'm assuming it's coming from the fuse box), but the car does not turn over like there is no power going to the starter. I hear a small buzzing sound on top of the engine when I turn the key, but it's not coming from the starter. It did this to me last week as well, and after trying EVERYTHING I could think of (locking and unlocking the doors, moving the shifter, checking lights and all accessories, cleaning battery terminals, rolling the car back a little, jumper cables) to no avail, I stepped back and talked to some friends then tried it again and it started. :wtf2:
Now, my roomate and I have both had the problem where the key is really hard to turn, or just won't turn at all. I have to jiggle the hell out of it, take it out, repeat until it finally turns. Other times, it has no problem. My friend thinks it's the ignition switch causing the problem, I have no idea. Also right now the car is not here at home, I have to go to it later today to try and get it started, but i will answer any additional questions best I can.
Any ideas?
ARKQX33V6
Starter motor at end of useable life, check with a hammer, next time a no start, go under and smack the starter, if it turns it needs to be rebuilt or replaced.
broc5k
THANK YOU!!! Took out the hose to the airbox and tapped the starter a few times, turned over like a champ and now it's home. The starter seems easy to replace, however any idea what it's going to cost me? What's the cheapest way to get a reliable starter? I'm so broke right now it's not even funny.
Also when I reconnected everything and started the car, now the "Service Engine Soon" light is on, is this because I disconnected the sensors on the airbox hose?
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
ARKQX33V6 wrote:Starter motor at end of useable life, check with a hammer, next time a no start, go under and smack the starter, if it turns it needs to be rebuilt or replaced.
+1
broc5k wrote:Also when I reconnected everything and started the car, now the "Service Engine Soon" light is on, is this because I disconnected the sensors on the airbox hose?
Did you re-connect it?
broc5k
SteveTheTech wrote:Did you re-connect it?
Yep, re-connected everything and that's what I got.
SteveTheTech
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
Well than you probably had the key on, or cycled it with the intake air temp sensor disconnected. Should clear itself in a few weeks if nothing is actually wrong.
