VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Sun Jul 25, 2021 6:44 am
The P0325 is a knock sensor code, it won't cause rough running. Degraded performance when warm often indicates a vacuum leak or a dirty or lying MAF sensor. I doubt you're looking at an individual injector, that would cause a dead miss but not a P0300 or near-stalling. There are a couple of peculiarities on the 3.0/3.3 that you could also look for. One, since it was just worked on, it's possible on most of them to accidentally swap the front O2 sensor connectors. That will cause all kinds of crappy-running issues. Second, the ECM uses the CMP in the distributor as the sole source for piston position, the crank sensor is for misfire-diag and nothing else. When the distributor bearings go bad, the thick oil when cold will often keep them stable but then they screw up when the oil thins out.
