blockmachining »
https://forums.nicoclub.com/blockmachining-u89408.html
Wed Nov 04, 2009 9:07 pm
The knock sensor on the VQ30 engine is located directly under the intake. It is mounted to the top of the block right in the center using one 12mm bolt. It is round and black with one connector. It is a bear to get at with the intake on. It can be done, though. Your engine was built in Smyrna, TN and then shipped to Avon Lake, Ohio for assembly at the Ford plant up there. The Mercury Villager and Nissan Quest were built on the same line.
