1997 q45 runs and cut off
leightontrouble
Car: 1997 q45
i have a 1997 q45t its runs and then cuts off it starts right back up. you can smell the gas burning and its smokes from time to time. The rpm is also idleing up and down. the rpm goes really low and somtimes cuts off ans omtimes it goes up to 2 and the just drops down and cut off. i only use premium gas in it .do you think its a gas problem because its burning the gas really bad. Yes i searched
Q451990
My first guess would be the MAF (mass air flow sensor) - but that's only a guess.
Heath
Q45tech
Good guess, substitute a KNOWN GOOD MAF.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Start by checking the MAF connector. Not really a known problem on the VH41DE.
Maybe someone tried tocahnge the oil filter from the top.
hsujohn
I hope you find the problem soon
leightontrouble
Car: 1997 q45
would the MAF cause it to smoke also
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
If it failed in a mode that made the ECU think there was more air than there was passing through. Not sure if that is even possible.
