1997 I30 hard-start
doberdog
Car: '97 Infiniti i30
My I30 doesn't start on the first time cranking over unless I quickly depress the accelerator on-off while cranking. If unsuccessful on the first try, it will always start on the second try. I saw a post stating to allow the fuel pump to come up to pressure by turning the ignition key to "ON" for a few seconds before trying to turn-over. This is not a huge issue except I want to use the remote start feature this winter ... hopefully. I bought the vehicle used and it has a Viper 5900 security/remote-start system but did not come with a fob. Hopefully I can get an aftermarket fob programmed correctly.
I will doing some routine maintenece in the next couple of weeks to include plugs and fuel and air filters.
maxhopper
Car: 02 Maxima SE 6spd
Check fuel pressure. It could possibly be the starter wearing out.
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
With Ignition switch to ON, the fuel pump will run for @ 5 seconds and then shut off. So if you leave it ON for a few seconds before starting, it allows the fuel pump to prime the fuel line, improving the chance of successful start. So "max" is right to check the fuel pressure - @ 43 PSI with Ignition ON, engine OFF and 38PSI with engine running. If you haven't replaced the fuel filter (besides brake booster), then it's likely the culprit.
