06_blkout »
https://forums.nicoclub.com/06-blkout-u162557.html
Mon Dec 26, 2011 9:03 pm
I'm not really familiar with the GA16, but you should need a 10mm socket (I'd bring a 1/4" drive set in case it's not a 10, but it's guaranteed to be in that set), something to pry off stuck parts of the pan, and something to scrape off the old gasket with. You should just need a new pan and gasket, but make sure none of the pan mounting bolts got bent by the deer, they're pretty fragile.
Good luck with the repair!
