1996 240sx recently won't start, need help
ep3721
Car: 1996 nissan 240sx
I drove my 240 across town, then came back to my house; one hour later it wouldn't start. The battery, fuel pump and starter are good and working, but I'm not getting any fire from my plugs now! Any ideas of where I should start checking and replacing? note: when I try to crank it, it turns over but doesn't start. All my check engine lights come on as usual. Thanks for any help
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
ep3721 wrote:I drove my 240 across town, then came back to my house; one hour later it wouldn't start. The battery, fuel pump and starter are good and working, but I'm not getting any fire from my plugs now! Any ideas of where I should start checking and replacing? note: when I try to crank it, it turns over but doesn't start. All my check engine lights come on as usual. Thanks for any help
1. make sure sure your Battery terminals are good and tight.
2. check engine grounds
3. I think S14 have an internal coil. so check your distributor cap and rotor for wear.
4. Still no spark, it might be the distributor.
I'd also check the plugs and see if there is any sign of unusual wear. example: burnt, oily, fuel covered.
ep3721
alright bro, I'll start with what you stated, get a multimeter and check the dist-cap and get right back with ya. Thankx bro
redmachine
I am not too familiar with the 96 240's, but if it's anything like my 91 and if there is no spark from your plug or plugs, chances are it might be a bad coil. One thing about coils either they work or they don't. They don't give you any indications that there is anything wrong until they stop working.
Dougbo9807
Car: 95 240sx
Had this happen to me over the weekend and it turned out to be a bad ground and a bad connection on the battery. I would check those first as thats an easy fix.
