I've been lurking in these forums since March of this year when I boughtmy 1995 Q. I didn't notice the symptom at first, but now do.
The car has 130K on the clock.
I have "used the power of the search button" and have found problems that come close to what my Q is doing, but yet do not match exactly for a 1995Q.
When I first start the car and drive, the problem is not noticable; only after the engine temp gauge is at 3 o' clock.
The symptoms:
When starting from a dead stop (red light etc.) I gently accelerate and feel a funky vibration. It seems to last until I'm out of second gear.
If I gun the accelerator, I still feel the vibration, but obviously, as the car exits second gear faster, the vibration ends faster.
The vibration is most pronounced from a dead stop going up an incline.
The vibration is not in the steering wheel; more like...well, I'm not sure; seems like from under the car towards the front.
Passengers generally do not notice the vibration; though I suspect any of you would were you riding with me.
Something else I noticed today that has not previously happened:While sitting at a red light there was enough vibration to make somethingin the defrost vents at the bottom of the windshield rattle.When I put the car in neutral, the vibration settled down and the rattle disappeared. Back into Drive and the vibration/rattle started up again.This was intermittent in my drive around town.
The previous owner did all kinds of nifty stuff (bilstein engine oil flushes, transmission flushes etc) really pretty regularly.
The only thing it appears that he didn't do was replace motor mounts when the dealer recommended it.
The other symptom is after I've been at speeds above 45 or get a little happy with the accelerator on the freeway, when I'm at a stop again (red light) or park the car, I smell what smells like burning grease or ???
I wish I were a gear head, but alas, don't have it in me, so will likely take the car to Jerry Tucker (as many on this board seem pretty positive about their work).
What I would like to do is change the air filter (after all these fires we had here). Could someone recommend a brand and source to buy one from?
Thanks
