Massive Parts List
*Anything without a price next to it was purchased with as a group with the parts under it; the bottom part with a price is what was paid for that group of parts*
-Block
-Rods
-Timing Chain
-Crankshaft-------------------------------------------------------------------------------------- $100
-Mckinney Motorsports Motor and Transmission Mounts ---------------------------------- $414.58
-Pistons pressed onto rods
-Bore Block .060 over
-Hot Tanked
-New cam bearings and freeze plugs
-Crankshaft turned .010------------------------------------------------------------------------$297.02
-Main and rod bearings
-SB Gasket Set FELPRO #260-1000
-Crankshaft Key
-Mahle Flat Top pistons-------------------------------------------------------------------------$110.00
-Mckinney Motorsports Oil pan and pickup (private seller)---------------------------------$400.00
-Aluminum Heads from Patriot Performance-------------------------------------------------$500.00
-Wolverine Camshaft and matched lifters----------------------------------------------------$50.00
-Edelbrock Single Plane Torquer II Intake Manifold------------------------------------------$50.00
-Mr. Gasket Timing Tab; MRG #4592---------------------------------------------------------$1.92
-Renegade Racing Oil pump stud; REN #42150-----------------------------------------------$2.95
-Renegade Racing Oil filter adapter; REN #49523-------------------------------------------$6.60
-Renegade Intake manifold bolts; REN #58400-----------------------------------------------$7.00
-Renegade Timing Cover bolts; REN #58590-------------------------------------------------$1.54
-Renegade 3/8" Rocker Polylocks; REN #69350-16------------------------------------------$11.33
-Professional Products Harmonic Balance; PRO #80000-------------------------------------$30.58
-Comp Cams Magnum Roller Rockers; COM 1412-16----------------------------------------$134.28
-Comp Cams Push Rods; COM #7812-16------------------------------------------------------FREE!
-Melling IS-55E Oil pump driveshaft-----------------------------------------------------------$6.35
-Melling M55 Oil Pump--------------------------------------------------------------------------$12.97
-Pioneer oil pan bolts; PNR #S1100------------------------------------------------------------$2.46
-Milodon Timing cover; MIL #65555-----------------------------------------------------------$23.95
-Moroso Fuel Pump Block-off-------------------------------------------------------------------$4.98
-PRW Short Water pump; PRW #1435000----------------------------------------------------$53.47
-Bandit Truck Accessories T-Wignuts; BAN #6019------------------------------------------$10.88 for 8
-Borg Warner T-10 Transmission 4 speed----------------------------------------------------$500.00
-Motor Lift Plate--------------------------------------------------------------------------------$3.61
-Moroso Engine Storage Bag-------------------------------------------------------------------$6.53
-Barry Grant 4150 carb rebuild kit; BGF #190003-------------------------------------------$20.99
-Holley 4150 Carburetor w/ vacuum secondary no choke----------------------------------$120.00
-Chevy Starter----------------------------------------------------------------------------------$58.69
-RCI Coolant Overflow catch can; RCI #7040D-----------------------------------------------$11.33
-Renegade Racing -6an carb inlet hose with black nylon; REN #75117BLK---------------$25.06
-Ram Clutches Hydraulic Release Bearing; RAM #78125-----------------------------------$108.99
-Mr. Gasket Flywheel Bolts; MRG #912-------------------------------------------------------$4.47
-Ram Clutches Premium Clutch; RAM #88761-----------------------------------------------$106.60
-Energy Suspension Power Steering Bushings ENE #7.10104G-----------------------------$6.33
-Taylor Aluminum Trunk Mount battery box TAY #48101----------------------------------$117.57
-Flywheel FW350-153--------------------------------------------------------------------------$87.13
-Autometer Pro-comp Water Temp Gauge; AUM #5437-----------------------------------$50.24
-Autometer Pro-comp Tachometer; AUM #5161--------------------------------------------$100.68
-4 Speed bellhousing---------------------------------------------------------------------------$75.00
-PCV Grommet and VC t-bars-----------------------------------------------------------------$2.98
-PCV Valve---------------------------------------------------------------------------------------$2.16
-VC Spreader bars, Filter Breather, and carb studs----------------------------------------$9.26
-Intake Gasket Felpro #1206------------------------------------------------------------------$14.53
-Marshall #160015 Fuel Pressure gauge-----------------------------------------------------$12.23
-Redhorse Fittings-----------------------------------------------------------------------------$14.87
-Royal Purple Gear oil--------------------------------------------------------------------------$22.64
-Dispstick---------------------------------------------------------------------------------------$17.27
-More Redhorse fittings-----------------------------------------------------------------------$9.91
-Fuel Lab Billet Fuel Regulator #51504-1----------------------------------------------------$102.71
-Enjuku Racing Cooling package, aluminum radiator and twin elec fans----------------$300
-Rigid Racing Wilwood Clutch Master cylinder adapter------------------------------------$20.80
-Clutch Pedal Assembly (Nico Member!)-----------------------------------------------------$55.00
-New V-Speed Front bumper (no more snowplow)------------------------------------------$230.00 shipped
-Wilwood Clutch Master Cylinder PN#260-1304---------------------------------------------$48.00
-Stock Clutch Master Cylinder----------------------------------------------------------------$15.00
-Lower Shift Boot for S14---------------------------------------------------------------------$10.00
-Autometer Speedometer #5153
-Autometer Oil Pressure #5427---------------------------------------------------------------$160.00
-Custom Gauge setup (incl. shipping)-------------------------------------------------------$300.00
-West Covina Nissan OEM Radio Bezel------------------------------------------------------$55.92
I am trying to make this as complete and accurate as possible with part numbers. It will be updated everytime I purchase something for the project. I believe this helps give people a realistic idea of what it really takes to build a good project. If there are any questions about the parts feel free to ask!
Happy Building!
~Speckid~
