mej30guy »
https://forums.nicoclub.com/mej30guy-u105785.html
Thu Sep 18, 2008 3:43 am
I checked the RPMs with a warm engine, and got a 660 reading with my foot on the brake. (1 line below 1000) So I guess that's ok.
I checked out the knock sensor connection at the top of the engine and found a couple of things. First, what looks like the proper end has a yellow wire coming out of it like in the picture. Also, those wires go into a heavily taped black sheath, across the top of the engne, and into the firewall on the passenger side, hopefully to the ECU. Secondly, the other end looks like it goes down into the middle of the engine, directly to the ks. Is my assessment correct?
I received a call from a friend of mine last night who again spoke with a couple of mechanics. When he described my J's symptoms, they immediately ruled out a bad ks, and said it was most likely low fuel pressure. Their reasoning, "How would the ECU know to retard the timing if it wasn't getting a signal from the sensor?" My thought is, because it doesn't get a signal that everything is ok, the engine defaults into a retarded timing as a fail safe to guard against major league engine damage.
The possible fuel pressure issue flies in the face of the fact that I can cruise at 85mph and 2700k without a burp from the engine.
On the bright side, I found an OEM Infiniti ks for $49.95 with free shipping and a 5 year warrantee on e-bay.
Oh the humanity!!!!
