3Q Jay »
https://forums.nicoclub.com/3q-jay-u16163.html
Tue Sep 11, 2007 6:44 pm
Hej Markus!Welcome to NICO. wow, an active in Sweden! is it a USDM or JDM? getting parts must be a challenge?
as to your question: i hope you put solid M8 bolts (not the ones that were there!) in when you used the breaker bar--the hollow core bolts that pass the active fluid into the actuator bend quite easily. after removal of the hydraulic fitting, you just want to loosen the 'mushroom' cap on top (not necessary to remove, but will help you later), then remove the actuator via the two nuts on top of strut tower and single nut on underside that attaches to 3rd link. the accumulator can come out with the actuator. at the bench, install your spring compressors as you would for conventional spring, and compress until you can unscrew the mushroom and you know the rest.don't forget to change the bumper bounds while you are doing the boots.
