bigdrummer67 »
https://forums.nicoclub.com/bigdrummer67-u215758.html
Sun Feb 10, 2013 6:13 pm
I am trying to figure out a problem with VSS/Instrument cluster problem. I replaced the VSS and speedometer/odometer worked fine for 2 days then it fluttered and quit totally. I checked the eccs code and it came up with #14 VSS. I checked the Instrument cluster and then found the CEL, ABS and the light next to it(can’t remember what it is)aren’t coming on. The three on the left. I checked the wires from the transmission harness plug for VSS to the harness behind the battery and it had continuity. I am no electrical guy. I also found an Instrument cluster in a salvage yard and it performed exactly like the original. The three most left lights never came on and speedometer/odometer won’t work. Tach, fuel, temp all work fine and the lights on the right side of Instrument cluster are fine. Oil,brake,seatbelt, can’t remember the last one. I cleaned all electrical connections in truck. Instrument panel, grounds, harness plugs, relays, everything I could get to. I am at a total loss. Can anyone help?
