1991 D21 Instrument Cluster
Lakehimself
Car: 1991 D21 Pickup
My 91 Pickup has the bare bones instrument cluster, I want to put one in with a tach. A few questions:
1. Is it even possible
2. If it is what clusters work, I assume from 86.5 to 93 works, as long as it wasn't an automatic since mine is a 5 speed
3. I have a few extra connections behind the cluster and I assume thats what they are for, if not how much extra wiring will it take.
Thanks.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
1993 will not work, all the connections are different. The extra connections are for the tach and a clock. It is possible and missing member mrecoolgar started a thread about this subject. Search his name and it should come up.
longtooth
Car: 89 d21 HB
This is a popular question and I believe a search should show you the build thread that have been done.
Here is a link that I got on a quick search. Hope it heads you in the right direction.
post6353868.html?hilit=tach#p6353868
