onpoint357 »
https://forums.nicoclub.com/onpoint357-u38549.html
Wed Apr 19, 2006 2:19 pm
Yes I have good spark good fuel preasure and now you can ad to the list a new ecm. Result, still shuts off. (I tested pulse using noid lights) Just to let you know Repaced parts include: Mafs, throttle position sensor, fuel pump, fuel pump relay, distributor cap and rotor, ecm, fuel filter coil ignition module. After changing the ecm I drove the car about tem min with no problem then it shut off. It started but shut off as soon as I touch the gas. I sat for about an hour and It started like nothing ever happend. I got it home shut it off and tried to start it again it started shook and shut off. I have no clue, and about to give up.
