1990 Redo Transformation
mrecoolgar
Car: 1990 Hardbody Reg Cab 2WD 2.4 5SP
Here are the door panels Rev.The armrests are ig good condition as well.But I need to really dig to get at them.This use to be an open area, 6'x12'.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Those look great except the fact that I would be forced to add power windows to my truck. Is the master switch pack for 2 or 4 windows? And how much would you be looking for them anyway?
mrecoolgar
Ooopps, I forgot about that.Never mind.I'll be posting them on Ebay soon.Along with the rest of my stock.
Modified by mrecoolgar at 4:29 PM 2/20/2010
mrecoolgar
Warm weather is here so I got back on the Hardbody.I found this spare in a Pathfinder.It will replace my current 14" white wagon wheel.And I installed the molded headliner and A-pillar grab handles.Note the rear headliner lamp.
steveOd21
Car: 94 nissan D21 2.4 5sp base
whats up guys? i ve been kinda idleing on my truck proj haha i got a new computer and some shxt but anyway. Since then i got some black racing seats i swooped up at the swap meet for 40 each wow yeah they have damage on the back but i dont care there in a truck and stock seat brackets so they bolt in lyk stock pretty nice. And a K n N . I broke down and ordered a new front hb bumper i was thinking about swaping a 99 pathfinder bumper but i want to keep the sleeper look. I got 4x4 fenders grill and corners from a yard so i will finally be fixing the frontend cosmeticsnice donar i almost got thoe 4x4 rims but they wanted my rims plus $200 what do you think? KnN! plus seats thats lyk 7hp
Hey Mrecoolgar ever put A/c on a truck w/o a/c ? i wanna do it to my truck i think it would be simple all for the evperator . do you know if the dash has to come out?
mrecoolgar
$200 plus your rims is too much, and odd to ask for.I have intermintent wipers to add next.Then a remote entry system.Then an illumination circuit to add glovebox lamp, ashtray lamp and ect...Then I'll be finishing adding the ac.Underhood you need: ac comp with mount, fan belt, hi + low pressure lines, condensor and a relay .The relay plugs into an existing connector.Your crank pulley will be a 3 belt, or at least mine was to cover the ac and ps.In dash you'll need the ac switch and the evap core plenumn.The dash switch will fit into your existing controls.The evap core plenum will replace the non ac plenumn.That's just off the top of my head.I will be removing my dash to do the ac because the system and ductwork need a good cleaning.Keep us informed of your doings.
Gogolinskiy
Car: '87 Nissan Pickup King Cab 5spd RWD
I got the same problem with the Tach,its there and it doesnt work,by the way does anyone has a digi tach that works any pics?I love my 87 5spd King Cab rwd HB....Thing i Done to it Since i bought it....Steering bolt joints -upper i thin(# knocks with a hammer and they were out)Alpine Deck 9881 with MA Audio 6 1/2 Speakers and 5 1/4 Centre speaker.12" JL Sub,MTX 2 channel amp.Had some offset rims took them out ,put some pathfinder chrome one 235/75/15changed the Side markers at the front for the Pathfinder one'sTook the hatch at the end off and put a net..Got a Some Infinity Leather Seats fully power and heated(heat not connected yet)Some Sylvanie Ultra-x something Headlight(the best one from canadian tire)Low beams broke so driving with high abjusted for lowGot a newer sportback mat for the bedA newer hood custom painted with a brush:))) looks like Carbon fibre)))Bush guard to come and hopefully some 285/60/15 in the back and some 205/60/15 in the front Picks to come...
edit....pics are in the pictures topic!
Modified by Gogolinskiy at 12:16 AM 5/8/2009
mrecoolgar
Your low beam problem may be with the headlamp switch.Mine had the same problem and it was the first thing I fixed.I took my stalk switch apart to repair.But later replaced it with a cruise unit.
Gogolinskiy
Maybe....but first my right went so i was driving with left only....i do a lot of driving on bumpe gravel roads,might be the reason and then wehn i started the car my left one was gone i died like the battery discharged....on of dim on dim dim off.....((( now i drive with my sylvanie extrabright high beams:))lol ubjusted them to the lowest point!
Rev_D21
Mine came with a burned up H/L switch. That was just the easy part to find and fix. Someone had made a rats nest of a wiring job fixing a headlight that didn't work (wired the headlight into the parking lamp when the whole time it was a fusible link that had pulled out). Either way that fried the T/S pretty good. Unrepairable I might add. Got one for $20 at a yard.
Gogolinskiy
still cant find the problem:(
mrecoolgar
That's the way mine was when I first got it.I fixed the switch then undid the quick fix wiring.Then I eventually got another head lamp switch.
mrecoolgar
Did a leak down test and found #2 cylinder was leaking into the coolant.Bubbles would appear in the radiator.This was done after finding a cracked insulator in the #2 plug.I will be trying a gasket sealer system in another week or two.I'll let you know how it works.
mrecoolgar
I have a bunch of parts left over and they need to go.If anyone is interested and it's worth the drive, come take a look.Most items will be free.I'd hate to pitch what someone else could use.
kibatheloanwolf
Car: 1987 D21 2.4L with a 5 speed manual trans
2010 Camry 2.5L with a 6 speed maunal trans
mrecoolgar wrote:I have a bunch of parts left over and they need to go.If anyone is interested and it's worth the drive, come take a look.Most items will be free.I'd hate to pitch what someone else could use.
Hey if i Pay shipping Will you send it? And what do you have ? lol
mrecoolgar
Updated 2009-11-11
Nissan Hardbody And Pathfinder Parts For 1987-1993 Hardbody and 1987-1995 Pathfinder Some parts are interchangeable between Hardbody and Pathfinder Most parts are for 1987-1993 except where noted Will Email photos
Blue Interior: Fuse, lower steering column and emergency brake covers - $1 Lower center dash cover - $1 Rear wall carpet with seat belt hooks - $5 Rear wall speaker covers one cracked - $5 Tilt column cover missing lower tilt lever cover - $5 Headliner map light with mount - $10 Sunroof case - $20 Visors has passenger mirror - $20
Red Interior: Visors has passenger mirror - $20
Taupe Interior: Glove box - $1 Door panels deluxe for manual windows - $40 Door sill pair - $1 Lower steering column cover - $1 Door handles, window cranks and lock knob set - $5 Door panels base model with map pockets on both - $20 Door panel speaker grill pair - $10 Visors no mirror - $10 Armrest pair nice - $40 Armrest single - $20
Gray Interior: Door handles and lock knob set - $1 A-pillar trim with speaker grills and speakers - $20 Console armrest pad, missing one cup holder - $20 Headliner and A-pillar grab handle set - $20 Wind lace from four doors - $1 Jack cover - $1 Side trim Pathfinder style 6 pc - $1 Gages for above for auto trans - $60 Pathfinder rear roof speaker covers - $10 Visors no mirrors - $20 1994 Steering wheel with cruise, includes contact ring, gray - $101994 Steering column cover gray - $11994 Steering wheel leather with cruise, gray - $20
Pathfinder Interior: Owners manual 1995 4pc set - $1 Power window and power lock switch set - $20 Jack with holder, cap, pouch and tools - $20 Headliner lamp - $1 1994 Head lamp switch - $201994 Wiper switch variable - $201994 Gage cluster with harness, AT - $60
Hardbody Interior: Jack with mount - $1 Shift knob for 4x4, can use for trans knob - $1 Door speaker mounts oval - $1 Factory Clarion amp - $5 Owners manual 1986 has one pen mark - $1 Owners manual 1991 Hardbody and Pathfinder - $1 Long bar to remove spare tire - $1 In mirror nice - $5 Dash ashtray with lighter - $1 Dash bezel for radio and climate - $5 Climate controls no ac or faceplate - $5 Dash bezel for gages in silver - $5 Door glass both - $10Wiper switch - $5 Window regulators - $1 Steering column with ignition switch, both door locks and 2 keys - $40 Steering wheel for above with center pad - $1 Folding rear head liner lamp for cargo bed - $20 Gages 1989 with tach, dual fuel tank and auto trans - $60
Hardbody Exterior: Front bumper lamp pair - $10 Cowl cover grill set - $10 Front bumper brackets for 4x4 - $10 Front air dam plastic - $1 Front fender flairs - $5 Fuel door with fuel cap holder, silver with blue stripes - $5 Grill for 1989 4x4 with passenger lamp - $20 Grill for 1987 - $20 Rear bumper license lamps with connectors - $5 Rear bumper license lamps only - $1 Wheel caps black plastic, 4 open and 3 closed - $1 each Lug nuts with locks 24 - $5 Wheel lugs with locks aftermarket 24, rusty but will clean up - $5 Windshield trim set top and sides - $1 Rear license plate holder with lamp - $1 Rear valance beige - $5 Door handles - $1 Front bumper ends chrome - $5 Passenger front fender - $20 Nissan fuel cap - $1 Hood deflector - $1 Hood inserts 2 - $5 Side mirrors - $10 Bed pop up tie down set of 4 - $20 Hood - $40Spare tire full size 14” - $10
Pathfinder Exterior: Front valance metal charcoal - $20 Silver 4x4 emblems - $1 Fender flairs with molded mud flaps set of 4 - $60 Fuel door with fuel cap holder silver - $1 Roof rack chrome 10 piece - $40 Spare mount with bracket, lock and key - $5 Hatch wing - $20 Spare cover - $1 Fuel door with fuel cap holder charcoal - $1 Drivers head lamp with corner lamp - $20
Hardbody Under Hood: Prop rod - $1 Wiper motor with intermittent - $10 Wiper motor - $5 Radiator support to hood rubber shield - $1 Power steering reservoir - $1 Injectors for 2.4 - $60 Steering box for manual - $20PS reservoir - $5Radiator with fan shroud - $20
Pathfinder Under Hood: Accelerator cable - $5 Auto trans shift cable - $1 Cruise control units for auto trans and V6 - $20 Windshield and hatch washer fluid tank with motors - $10 AC heater hose block off valve - $5 Air box with MAF - $20 Computer for auto trans and V6 - $40 AC hi and low lines V6 - $10PS line set V6 - $10
Maxima 1997: Gray visors with mirrors - $20 Ashtray, lighter and 12V plug - $1 Master power window switch - $10
Quest : Gray headliner lamp with power rear vent switches - $5 Gray headliner lamp with sunroof switch - $10 Headliner lamps gray and tan - $1 Jack with handles - $1 Fog mount metal brackets - $1
Misc Nissan: Owners manual 1999 Altima, 3 pc with case - $1 Owners manual 1996 Sentra 2 pc - $1 Datsun B210 grill nice but not perfect - $20
Nos (New Old Stock) Nissan: Gray steering wheel - $60 Red seat cover for one bucket base and back - $80
Modified by mrecoolgar at 2:32 PM 11/11/2009
kibatheloanwolf
Carpet for reg cab nice - $10
Climate controls with AC - $5
Gage cluster standard with speedo - $10
Lug nuts 19 - $1
If you could give me about a week I would have the funds to pay you for shipping and such and again Thank you very much!
mrecoolgar
That would be fine.Did you want the 'Taupe' color ?Thanks.
Modified by mrecoolgar at 6:51 PM 7/8/2009
mrecoolgar
I also have a bunch of hardware, screws, bolts and such.These are for mounting fender flairs.
Modified by mrecoolgar at 8:03 PM 7/8/2009
kibatheloanwolf
mrecoolgar wrote:That would be fine.Did you want the 'Taupe' color ?Thanks.
Yes please and could you see how much it would cost to ship to 27524
And again thank you! Could you take a look at my "Cheap paint job!" thread to let me know how i did for a rattle can job?
kibatheloanwolf
All the way to the right third down i need a few of those. how much would they cost?
mrecoolgar
The grill retainers.Free with your current order.Just let me know how many.I believe 4 are required.
I also have the cowl cover retainers, new.Set of six for $5.Yes, they aren't inexpensive.
kibatheloanwolf
Okay I don't think I need those lol I'm going to a local yard that has the marker lights for about 13$ in a few days...I'm waiting for the 40$ Saturdays Anything you can carry over the line in your arms is only 40$ all together already scoped it out none of them have what I'm grabbing from you tho....
I might grab two pathfinder seats new speakers and a new Nissan logo and all the fuse's relays screws nuts bolts etc etc my pockets can carry...and i have a set of cargo pants that can hold a lot. Well wish me luck and as soon as this lady pays me for mowing her lawn you shall have your money as well.Hope you have a good day!
Modified by kibatheloanwolf at 2:14 PM 7/9/2009
mrecoolgar
Good luck.U pulls are fun.
kibatheloanwolf
Hey i checked behind the gauge cluster and i found 2 extra pugs one is a four wire plug that has two black and two white and the other is a two wire plug one red wire and one black wire do you happen to know what these hookup too?
kibatheloanwolf
Well the U-pull sucked....The only hard bodys that they had were gutted and being towed to scrap.. so now i gotta get some more money... How much does it all weigh?
Modified by kibatheloanwolf at 5:37 PM 7/12/2009
mrecoolgar
kibatheloanwolf wrote:Hey i checked behind the gauge cluster and i found 2 extra pugs one is a four wire plug that has two black and two white and the other is a two wire plug one red wire and one black wire do you happen to know what these hookup too?
One is for the clock, the other is for the tach.
mrecoolgar
kibatheloanwolf wrote:Well the U-pull sucked....The only hard bodys that they had were gutted and being towed to scrap.. so now i gotta get some more money... How much does it all weigh?
Allow me more time, I'm currently very busy.I should be able to get to it by Wed.
kibatheloanwolf
Oh no no Please don't rush take your time i'm having a few money issues right now so ill be a few weeks x.x
mrecoolgar
I gathered your parts today and will be able to ship all in one box.Thanks.Kevin.
Modified by mrecoolgar at 9:09 AM 8/14/2009
