1990 Redo Transformation
mrecoolgar
Car: 1990 Hardbody Reg Cab 2WD 2.4 5SP
My mechanic friend gave me ideas what to check next.
It seems the coil is not getting power.
There is one wire to the coil that will show 12v with the key on.
And mine didn't.
I need to run thru the schematics next.
It may be an isolated problem or the computer may need replaced.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Didn't you say you had spark though?
mrecoolgar
I do, though it is weak.
I tested the system per the shop manual, all checks out good.
It does appear to be timing, again.
I removed the distributor drive shaft and advanced it a tooth or two.
It's hard to tell.
It almost started while adjusting the distributor.
I'll be trying fresh plugs next as these may be fouled.
mrecoolgar
Today was the day.
I removed the cam cover and my mechanic he said... the cams off.
Sure enough, I had to counter clock it a tooth.
Which means compressing the chain tensioner with one hand.
Removing the cam sprocket and reposition it with the other.
Rev_D21
The suspense is killing me, did it run?
mrecoolgar
Sorry about that... yes.
Today I bought a used bed and installed it myself.
That was fun, trying to muscle the bed from upside down on the bed of my Ranger and placing it on the 4x4.
I also did the title work today then drove it home.
I need to go over a few thing before it's ready to pass inspection.
Der_Vier
Car: 1998 caR50
5-speed
AUx lights
Kenwood headunit
Stock and saggy
So once you get htem both running and road legal etc etc you keeping htem all?
Rev_D21
That's awesome! Congrats on getting her up and running. Truly an HB rescue story.
mrecoolgar
Thanks Rev.
I'll be swapping all my 2wd items to this 4x4.
And vica versa, then sell or part out the 2wd.
Der_Vier
Car: 1998 caR50
5-speed
AUx lights
Kenwood headunit
Stock and saggy
hmmm pending the condition of the 2wd I may be interested in it..keep us posted?
mrecoolgar
Will do.
I scheduled a repaint and dent removal for the cab.
I noticed the truck runs out of steam at around 4,100 rpm.
Guess I need to recheck the timing.
Oh, and the ac works.
Der_Vier
Car: 1998 caR50
5-speed
AUx lights
Kenwood headunit
Stock and saggy
nicee.. Just out of curiosity, how much would you be looking to get for it? I have to sell my R50 first before I can even think about getting anything else. Again, cna't promise anything definite
mrecoolgar
Were ar you from Der_Vier ?
I'm in Hershey PA.
After a week of driving with the bench seat, I had to install the buckets.
Again... what a difference.
MilkMan
Car: 97 Hardbody
I have been following this thread since I started as a lurker. I gotta say you did a great job with this truck. Gives me an idea to find a 4x4 wreck and rebuild it. Im lusting for a 4x4!!! My Caddy is great in the snow, but you cant go camping in it. LOL!!
mrecoolgar
Thanks MilkMan.
I'm releaved to have a 4x4 again.
On a side note:
I traded gage clusters on my 1990 2wd and my 1990 4x4.
When I drove the 4x4 I noticed the tach did not move.
Odd as it worked on the other gage cluster.
So I started my 2wd and . . . the tach worked.
Apparently my 2wd was wired for a tach even though it never had one from the factory.
Since it didn't work when I installed it years back I thought I needed to wire it in somehow.
If you want to add a tach give it a try.
Mine had the connector in the dash for the tach as well as the clock.
mrecoolgar
The inner rear wall stamping is different than my 2wd.
My 2wd.
My 4x4.
I'll have to fab a support bracket for the speaker mount lower attachements.
Rev_D21
That's how mine is, it's different than your 2wd back wall so I can't use the OEM speaker mounts without modifying them. Mine has the 2 lower holes but not the upper one. You seem to have gotten the upper one but not the lower. Go figure.
mrecoolgar
Body shop is behind schedule so the repaint is on hold.
I decided to look for a King Cab.
I did do some 4 wheeling at the junkyard yesterday.
mrecoolgar
I'm selling the 90 reg cab 4x4 and parting the 90 reg cab 2wd.
Reason ?
I got this on May 24th, see my 'Redo Transformation #2' thread.
ekswapdude
Car: 94 nissan "HARD"body sohc maual
that single cab headliner is a rarity... im dying to get my hands on one... cash in hand!!!
ekswapdude
mrecoolgar... do you have any spare? im rocking a pathy headliner piece for now... could you at take some better pics and of those plastics used to support it on the sides... i cant find anywhere that even sells the single cab cardboard... if you dont have any.. do you know anywhere that will sell it? please hit me up at 662-812-7957
mrecoolgar
Unsure what year they changed to the solid type headliner but I'm gueassing 1994 if not earlier.
The side trim will be with the headliner, unless someone prior needed it.
You can use the side trim from a Pathfinder too, although it will need to be shortened.
ekswapdude
well if you have the headliner and associated plastics to sell please hit me up at 662-812-7957 for a single cab 94 hardbody... not the a pillars but the rear plastics (boot shaped one for the seatbelts) i would really appreciate it.. or if you know of anyone selling these items that would be awesome... thanks in advance
mrecoolgar
I do not have any but may hit the yards soon.
mrecoolgar
mrecoolgar
mrecoolgar
mrecoolgar
mrecoolgar
Anyone need a rust free 2wd frame ?
Or 2.4 engine, 5 speed trans, axle, new exhaust ... ?
It's soon going to the scrap yard.
Rev_D21
2wd 5-spd trans?
