1990 Redo Transformation
mrecoolgar
Car: 1990 Hardbody Reg Cab 2WD 2.4 5SP
That probably is a shielded wire bundle and should be replaced.Or maybe someone in the know can repair it.
The corner lamp will fit but may not match up to your grill.
Oh, and your package went out on Tue.Thanks again.
kibatheloanwolf
Car: 1987 D21 2.4L with a 5 speed manual trans
2010 Camry 2.5L with a 6 speed maunal trans
Hey man I really hate to do this but do you think you can wait till Oct for payment on the seats I had to replace 2 tires a muffler and now blowing 89 bucks on marker lamps...
This is not a good time for my bills right now.. if you can't wait because you have another person interested in them by all means sell them I don't wanna have you lose money over me
mrecoolgar
Believe me, I know how it is.Don't worry about it, just keep me informed.
mrecoolgar
Wed I finished underhood by adding the compressor.It sits under the distributor.I had to remove the cap in order to install the compressor.I tried from under but it wouldn't go in that way either.Then I removed the dash.This is the section that gets replaced when adding AC.Thu I removed the climate ductwork.This debris is typical after 20 years.It was thru out all the ducting as well.I plan to add a filter at the fresh air intake to solve this problem.
Modified by mrecoolgar at 6:16 AM 8/22/2009
Modified by mrecoolgar at 6:19 AM 8/22/2009
Modified by mrecoolgar at 6:20 AM 8/22/2009
Modified by mrecoolgar at 6:42 AM 8/22/2009
Modified by mrecoolgar at 6:43 AM 8/22/2009
mrecoolgar
Fri I cleaned all the ductwork and started to reseal it.This is an example of the thin, sponge-like seals used.They are sticky and deteriorate over time.I replaced this type with adhesive backed felt.This is an example of the thicker foam-like seals used.They deteriorate over time as well.I replaced this type with adhesive backed foam.
kibatheloanwolf
Oh wow..I wonder how mine looks about now... Oh and thank you so much.. Would you happen to have a spare dash with vents? mine..has pieces missing an only 2 vents right now..
kibatheloanwolf
Got the package! I installed all the lil bits and had the odometer on the new on ran up to my current mileage its slowly looking good! thanks Kevin!
kibatheloanwolf
Any Ideas on why I'm only blowin hot air? lol I connected everthing lol
mrecoolgar
Sorry, no vents.They are hard to find unbroken.Glad youre pleased, thanks again.Elaborate on the hot air issue please.
kibatheloanwolf
Fixed! Linkage had slipped on the Flap that controls the hot/cold air movement
Modified by kibatheloanwolf at 9:22 AM 8/26/2009
kibatheloanwolf
Got any dimmer switches for the dash lights?
mrecoolgar
Got it fixed, good.I may have a dimmer switch.I had to replace mine as well.
kibatheloanwolf
Lol I might grab mine form auto zone or O'Rileys my dash is barely visible when I drive at night Oh and the white cluster is way better than that horrid orange cluster.
The white one has a nice blueish color to it which makes it better on my glasses and cuts down on the glare Would you like the old printed circuit board?
mrecoolgar
I do have a dimmer but I can't test it since my truck is apart.Please keep the circuit board.I'm trying to reduce inventory.
kibatheloanwolf
Good news! I might just have cash to spend i think about fifty bucks is what I will have free
Modified by kibatheloanwolf at 10:37 PM 8/31/2009
mrecoolgar
Let me know.I'll be glad to send what you need.
I was getting a wet carpet on the passenger side.I resealed around the windsheild but that didn't help.I resealed around the fresh air intake but that didn't help.It was leaking from the plastic cover that's above the fresh air intake.It was warped and the water clung to the underside then dripped straight down into the fresh air intake.I solved this problem by making another cover from tinted poly.Old.New.And I've been painting the dash supports.They come unpainted from the factory.
kibatheloanwolf
kibatheloanwolf wrote:Whoa... Happy birthday to me! My mom got me new brakes and marker lights!
Oh I ate some cake for all of Nico club!
And it was good
Modified by kibatheloanwolf at 1:19 AM 9/4/2009
kibatheloanwolf
Hey mow much for the Intake ducting+ mounting hardware and for the wingnuts?
mrecoolgar
I haven't been to the salvage yard yet.Sorry but times are hard.I only have the wing nuts and washers.
Q451990
mrecoolgar wrote:And I've been painting the dash supports.They come unpainted from the factory.
And I thought I was the only one who was ever nutty enough to do this! My old HB had a water issue too, and those supports were mighty rusty. I treated them with Loctite Extend (rust neutralizer) and then sprayed them with flat black paint.
Heath
volvo850
Car: Nissan D21 4wheel drive 1990
What a great idea and lots of work of course. I have a 1990 Nissan PU 4 wheel drive. I have had it for 15 yrs and now has 178,000 miles. I have been thinking of dumping it at some point but it hasn't given me a reason to do it yet. My interior and exterior need some work. Love the bucket seats. I am inspired. Runs great. Have never changed the timing chain.
SGiese
Car: 2016 QX50 AWD, 2008 G37S Coupe, 2007 M35 Sport. Retired: 2003 Infiniti I35, 2002 Infiniti I35, 1987 Nissan 200SX-SEV6, 1990 Nissan Sentra, 1993 Nissan Sentra, 1995 Nissan Hardbody, 1998 Infiniti I30
I have a 95 Hardbody with a destroyed front clip. Will the pathfinder front clip with inner fender or without work on this truck? I have found a 94 pathfinder I can get the clip form cheap. The front of my inner fender is pretty torn up but I just may be able to beat it out enough if I have to. Also we may be gifted a diffrent pathfinder of unknown year to get the front clip from as well.
Modified by SGiese at 2:13 PM 9/21/2009
pejsa s-13
Car: 91 HardBody, 85 720
you can run it without the inners LIKE ME
do the pathy front it cant possibly look work you might have some structure dammage behind that fender though
SGiese
Yep my problem area is going to be the front behind the headlight. We will try some banging it out first. Here are some shots with the skin off.
kibatheloanwolf
OW....What did you hit?
Modified by kibatheloanwolf at 9:04 AM 9/25/2009
mrecoolgar
Yeah, the Pathfinder body parts will fit.The dash is going back in now, slowly.I finally removed the pedals to paint.Proper wire harness routing followed by the climate plenums, 3 sections.All with new seals in and out.What a difference.
mrecoolgar
I still need to wire in the ashtray and lighter illimination, the glovebox light and intermintent wipers.Kiba - I'll be getting to the salvage yards after Oct 5th.Let me know if you still need the air cleaner hardware.
kibatheloanwolf
Okay I'll let you know by the end of the month man and btw looking good!
JC87HB
Car: 1987 Nissan D21 HB
mrecoolgar,
Hey man, do you happen to have any fender flares you are willing to part with? if so, how much for em?
mrecoolgar
I do.I have all 4 from a Pathfinder that includes the mud guards - $60 all.I had these on my Hardbody awhile and looked good.And the fronts only, no mudguards for a hardbody - $20.Thanks for asking.
