grantfc »
https://forums.nicoclub.com/grantfc-u59451.html
Mon Mar 12, 2007 7:44 am
HELP!!!! I haved searched through the forums and found a couple of helpful hints, but still confused! it all started before i left for work, i started the car like normal, about 15 seconds went by then heard this god awful grinding sound like the starter still trying to start, then it stopped. Drove to work no problems, when i got ready to go to lunch, the battery was dead! tried to boost, would not even make a click sound, i mean it would no do nothing. checked some fuses and found the hazard lamp, and horn fuse under the hood had blown, repalced....nothing. bought a new starter, everything seemed fine, 2 to 3 days go by, and i noticed that my interior lights do not work nor does the driver side power seat, passenger is ok works fine. I go to the store the other night, starts no problem runs great like normal, get to the store, cut off the car, keys in pocket go in.....come out 15 mins later car is trying to start by itself, the starter is turning over on its own. I pull cables and get it to stop, not sure what i done next, but now when i out my key in and turn it to the acc position the starter tries to start, not sure what i done, but when i removed the hazard lamp fuse the car started, i tried to hurry home with it, got about 5 miles had 1 to go and it died, now everytime i trie to replace the hazard lamp fuse even with the keys out of the ignition, the moment the fuse makes connection the starter turns? help
