DCaff300ZX »
https://forums.nicoclub.com/dcaff300zx-u136230.html
Fri Oct 23, 2015 3:09 pm
Welcome!
That "piping" is an air intake piece that keeps moisture down in the intake tract, which is VERY long in the Z32 for the VG engine. There are two of them, one each side and mount to the bottom of the crash bar or headlight cans IIRC, and larger ends to the ends of the air box. These pieces aren't mandatory for use (Nissan Z32 over engineering) and often we Z32 owners go to a cone filter setup that does away with the OEM airbox and piping altogether...but if OEM correctness is an issue for you (insurance, restoration project) these pieces should be in place, and can be purchased at most common Z32 vendors or easily found in parts yards.
