With a used transmission you're always best off getting the donor TCM with it if possible. It saves a lot of "re-education" headaches on trannies that have adaptive firmware or parameters stored in the Valve Body. I don't know if your Q requires any of that, but if you get the TCM then there's no need to find out.michaellong wrote: ↑Mon Jun 07, 2021 12:14 pmIs it possible to install a 1992-1996 transmission into my 1990 so that I will not have transmission issues anymore? Would I need to swap the TCU? My plan is to install an external transmission cooler to prevent this from happening again. Would it be best to bypass the radiator heat exchanger or install the external cooler in line with the radiator heat exchanger?
If you mean the "SuperCoolers" with the bypass built-in, they're basically doing the same thing as a standard cooler plus an external bypass, but the H-valve is embedded into the core of the cooler. There's no real advantage to it other than convenience, but no big disadvantage either. The valve obstructs the core so it will slightly reduce cooling capacity compared to a "clear" core of the same size, but I expect Holley/B&M will have accounted for that in their BTU ratings. It does save 4 hose clamps and a bit of complexity in the hookup, which might be a big advantage on a car with lots of clutter around the lower radiator. The 'stats all use very reliable shuttle valves, and the combined price of a Hayden cooler plus a Derale or Dana H-valve is pretty much a push with a similar capacity B&M. So I'd say it's a "you pick" depending on your vehicle and preference.
With a series installation, if the heat exchanger gets blocked then the whole cooler setup will be disabled. But the same is true of a blockage anywhere in the cooling loop. Since the flow stops, there's really no good way to automatically detect it and shunt around it. If that's a major worry (say, on an old trans with soupy fluid), the only thing you can really do is put in a transmission temp gauge and/or an idiot light to monitor it.michaellong wrote: ↑Tue Jun 08, 2021 3:44 amI usually hook external coolers in series with the radiator for extra cooling. It also helps in traffic and at idle when there is not much air moving past the cooler to keep the transmission temperatures down. However, I read that the heat exchanger gets blocked on these cars, and I was wondering if that means a blockage forms that prevents transmission fluid from flowing through the heat exchanger or if a blockage forms that prevents coolant from flowing through the heat exchanger.
The coolant flows around the atf heat exchanger in the radiator end tank(s).michaellong wrote: ↑Tue Jun 08, 2021 3:44 amor if a blockage forms that prevents coolant from flowing through the heat exchanger.
Good catch, I didn't notice he said coolant and not fluid and presumed he meant the latter.3Q Jay wrote: ↑Tue Jun 08, 2021 8:03 amThe coolant flows around the atf heat exchanger in the radiator end tank(s).michaellong wrote: ↑Tue Jun 08, 2021 3:44 amor if a blockage forms that prevents coolant from flowing through the heat exchanger.
