--There is no aftermarket parts but thank you...
--Seems as if my Hood latch is the see Saw point under hood.. Also I have read a form on hood adjustment..
Here is the latch and the three 12 mm bolts that need to be removed. The holes through which the bolts pass need to be enlarged. The two upper holes are on the latch itself.
--Evil ,, I need your help tho evil.. My new Z seems like it isn't getting enough air/gas, I have clean an replaced AIV FIAV, COIL PACKS, I have checked each plug an all are working,, -But when I unplug #2 an #3 an the engine rev the same... It has a little miss to it an I can't pinpoint it... -Next thing I will do is take off CAS an check injectors an Coils by turning post.Then trying to check Timing by using an old spark plug wire off a Sunfure..... I need to buy a fuel pressure gauge an a in line adapter... I appreciate any comments... My bad for mixing posts but I know that if any one on here knows what to do it will be EVL..U tha Man...
http://zclub.nicoclub.com/zerothread/473127
Modified by vape-one at 6:13 AM 1/22/2010
