http://www.es-ab.se/z-car/IdleTech2.htm ... eTech.html
After you try to start the car
If gas fails to literally spray out of the fuel line with the filter on it then you either have a blown fuse or relay... An more importantly faulty fuel pump..
Also there is a fuel shut off switch on driver side in hatch behind panel near rear tail light..
Also check for corrosion on injector wiring an the grounds for injectors.
Also you might wanna Take spark plugs out an ground a plug on plenum an have a buddy turn Z over an see if your getting spark..
Hope this helps..
