Hey everyone, i picked up another TCU, and indeed it WAS the tcu bad... 23 year old TCU ... about time it went i guess. Shifts like a dream now.
Let me recap all that i done for those that may have the same issue in the future.
If your automatic transmission has these symptoms:
AT check lamp does not come on every time you turn the key on with the shift leaver in park and OD switch on
AT does not shift into 1st gear when placed into drive, starts out in 2nd gear, and refuses to shift.
AT diagnostic mode reports no problems.
AT WILL shift if placed into diagnostic mode, and engine started and drove down the road.
1st. Check revolution sensor, Pin 25 should have 1volt AC or greater at 19 mph. This can be accomplished with a small piece of wire and a DVM with sufficiently long enough leads. Use the wire to probe Pin 25 , and ground the other lead, place the meter within view, and drive down the road.
2nd. If 1st is OK, as if the revolution sensor will throw the TCU into limp mode, and exhibit most of the symptoms above, check for battery voltage on pins 4 and 9. Pay careful attention to the pin out of the TCU connector, pins 4 and 9 are right next to each other.
3rd. Check grounds on TCU connector, pins 15 and 48. Should be straight ground , 0 ohms.
4th. run a Self Diagnostic. If Diagnostic turns up nothing, and AT check lamp does not come on EVERY time you turn the key on with the gear selector in park with the OD switch on... and 1 through 3 are good, replace the TCU.
With all that said I apologize for not posting sooner, i got the new TCU yesterday, however it was rather late by the time I got home. Went out today and rechecked all the pins for power and ground before I installed the new TCU before I hooked it up and took off down the road. And it's amazing what a difference it made. shifts 1-2 , 2-3, and 3-4 are all pretty firm. And synchronized perfectly. Thank you all on the Nicoclub forum for your help, assistance, patience, and time. I'm learning my car as fast as I can, and if I can help anyone here that's new to the 300z I will be glad to help.
