N/ayella wrote:A bad ignition unit won't through a code? Cause this car was made in like 1989.5 early production of z32 body style and I don't think there is internal damage... and even if the motor was over heated it would still give spark or sputter. I had a blown 427 in a Chevy that ran great until it was warm then it died
yeah, common problem on the z32. no spark is nearly always the ignition unit and there's no diagnostic for it other than to just replace it. the wires lift off the contacts and start to make intermittent contact so it can just fail catastrophically or cut in and out.
you cant really tell if it's overheating because no coolant = no temperature reading. try running an engine without coolant. your heads will melt before the temperature gauge starts rising.
there are a few tricks to get a warped or cracked motor running. you can throw in sealants that work for a little while. an egg will seal a cracked radiator if you add it to your coolant. you can join a few batteries and crank the motor for a few minutes to warm it up so the metal expands enough to seal itself until it gets cold again.
code 34 is just knock. the ECU has two sets of maps. one for knock, the engine runs rich and retarded. another for everything is fine. when it's running the knock maps, it runs rich and limits the turbo pressure. this is to stop the engine from running too advanced, too lean or at too high a pressure, essentially limiting the power output of the engine by limiting the compression forces. the knock code is unrelated to the ignition problem. code 34 can also be caused by bad engine mounts as it is basically just a microphone that listens for pinging noises.
