BlackScorpion »
https://forums.nicoclub.com/blackscorpion-u96236.html
Mon May 05, 2008 10:38 am
Hi there,I have a 1990 240sx Automatic with fairly high mileage.Only had it for a couple of months, and it's been running great. Completely stock, not modified in any way - lady driven most of it's life. Never any clicking or any weird starter problems since I've had it.
This morning, went to start it and the starter got stuck spinning away. It wouldn't turn over the actual motor of the car, just the starter was spinning. I guess the starter motor was spinning, but its solenoid didn't actually engage the starter gear to the flywheel?
In any case, I couldn't get the car to start. I pulled the key out and the starter was STILL spinning!!! I was stunned! Tried starting it again, and no difference - starter just kept spinning away.
Anyways, I eventually disconnected the battery, reconnected it, and everything was fine again. I was able to put the key in and start it like always.
I'm trying to think of the logic behind the starter:1. the ignition key is turned activates some sort of relay.2. the relay energizes the starter.3. when the starter gets energized, it both spins and pops out to engage the flywheel at the same time.4. when you release the ignition key, the starter relay stops energizing the starter.
For the symptom to happen, I think there must be more than one failure - the relay would have to get stuck AND the starter must be partially failing as well.
Or does the starter have two separate positive inputs - one for the spinning, and one that moves the gear out?
I haven't found any threads that describe my problem exactly, so I thought I'd try a new one.
Thanks!
