1989 Nissan Hardbody Z24 4 Cyl Need Help!
baggednissan1989
Car: 1989 Nissan Hardbody D21 Z24
Need Help From Technician
To the point: Starting the truck turns over and idles.... I can rev the engine no problems or hesitation at idle only!..... As soon as I put it in to gear and try to take off it will backfire in the tbi (5 speed) when I give it gas when at a low rpm it will pop (backfire) in the tbi. Cant drive it too much hesitation, but listening to the exhaust sounds amost at times its sucking air in and out. (sputtering) Please help
:confused: :tisk:
Dattebayo
Try checking the anti-backfire valve (AB valve) vacuum lines and hose clamps, maybe replace them, check valve operation, etc. It's located near the firewall passenger side under the air cleaner, has one big hose, one little hose. It's kind of a btich to get the hose on all the way sometimes when you remove the air cleaner.
Hey man, you should probably stop posting all this in the gen chat section. Keep it in it's appropriate forum... -> nissan-trucks-forum.html
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Moved this to the trucks forum. This is where you should post your questions from now on.
