This is a question I posted in the pickup forum in October, only one person tried to help and the advice was to post the problem here.
"Hi everyone, long time reader 1st time poster. Actually signed up just because of this problem.
Its a pretty frustrating problem. You start the truck with no problem at all, the idle shoots up to about 2k as normal(cold) but as soon as it starts to warm up and drop the idle will suddenly shoot down to 600ish then rise to 1k then fall over and over. A look into the tb shows what seems to be both injectors firing full then cutting then full then cutting over and over.
My work horse, 1989 d21 with a vg30i. Truck has 220k miles on it, about 10k ago I swapped the motor with a 88z31 motor(70k) but retained the stock d21 electro injection. Eliminated the egr and pump, added headers. Ran like a dream for a few thousand miles then all of a sudden the surging idle problem developed. I ran the codes, det sensor, maf sensor, cas codes came up. To my knowledge (and all datas too) the truck never came with a knock sensor but I added one and the code went away, maybe I'm wrong Idk. I replaced the maf with a used one due to the cost and that code disappeared as well. Replaced the entire dizzy with a z31 dizzy using a d21 cap and that code disappeared. The surging idle did not though. I checked the tps with a spare I had, nothing. If you leave it disconected the idle shoots to about 2k and no surge. Checked timing with a light, on the money. I changed the IAC valves with one I had from the z31 plenum (All data says they run the same current) No change. The air filter is clean. There is a bit of a gas smell in the exhaust although no smoke so its hard to tell if its running rich and I should replace the fpr or not because the egr and pump are gone. I have run the codes a few times as well as disconnected the bat to reset the ecu. I get no codes(before the reset of course:-)). I also tapped both injectors and checked the current, they seem fine. I also discovered while checking around with the ohmeter that the mixture heater is not working. There has always been a blown fuseable link (since I bought the truck)that I paid no mind since everything seems to work, all date shows that is the heater.
So thats where I am at. I am thinking fpr but at this point with all I have checked and been through I am asking for advice 1st. Just about had it to be honest, feels like maybe something stupid I'm missing.
I know there are many knowledgeable people here and someone is bound to help so thank you VERY MUCH in advance.
P.S. Sorry to ramble I just wanted to include everything I could think of to aid in diagnosis, thnx again."
After I posted that I was reminded of the chts, I checked resistance as per manual specs i.e. 68degrees = 2.3-2.7, 122 = .77-.087, 176 = .30-33 and it checks out almost on the money. I also checked every vac line and sprayed around everywhere with carb cleaner to check for a leak but found nothing at all.
The next day I checked the voltages to the chts and they fluctuate in sync with the idle surge. I checked a new chts and it was the same. That has been my only clue to date.
Thank you for any help.
