ok here is the problem , again 84 nissan 720 4x4 runs great on the road then i get on the dirt road headed home and it shuts off like it ran outa gas
and still it will run great till you hit the dirt roads then after hitting a bump act like it runs out of gas and need towed home then it mite start back up in 30 minutes or 3 days
also second issue is temp gauge is not working and not sure why had a shop get rid of all vac lines that i didn't need and got it back with the temp gauge not working
problem 3 only 1 coil is working replaced the coil not working and still not firing
soo if it is needing a new carb anyone found any webers cheap yet or is 250-260 about the best price i will find threw weber direct for the kit
also i have a 5speed and was wondering if 5th gear is always loud as in hearing the gears rattle or grind
