Msled »
https://forums.nicoclub.com/msled-u145727.html
Tue Oct 20, 2009 6:56 am
Hi, today I’m going to discuss the Choke, Idle screw, initial startup:
Ok first start up this morning B210 started up ran at Hi speed on it’s on; allowed this to go on for about five minutes or more. Notice that choke never opening up and when opening manually engine starts to stall, but I close choke back before stalling out.
I found the idle screw while engine was running, ran screw all the way down there was no change in engine speed.
Adjust throttle screw engine speed did go up and down a little. So after all of this maybe ten minutes has pass now. I open up the choke half way engine stalled out and after stalling engine would not run on its on power without holding foot to peddle.
Idle cutoff solenoid is on order.
