biosehnsucht »
https://forums.nicoclub.com/biosehnsucht-u13953.html
Fri Sep 09, 2005 9:57 pm
It's down to a software issue and I just haven't had the time to sort it out, the hardware works its a matter of finding the right duration for the cyl 1-4 sync points in the cas signal..
there are two outputs, the 1deg signal (so should be 720 per rotation presumably since we're measuring the cam), and the 180 deg signal (which goes active only at the 180 deg marks for cyl 1,2,3,4.. cyl 1 has a longer mark than the others)
signalling should be more or less the same as other 4 cyl nissans w/ CAS or dist such as KA, SR, CA.. similar also to VG and RB but of course they have more sync points for extra cylinders..
trying to count the blips by hand while slowly turning it is useless so I just need to mock up a slightly over-engineered prototype that spits out the timing information on serial port so I can find the proper settings to use.. just haven't got around to it.
