15 Versa Note SV rear door panel removal
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
15versasv
Car: 2015 Nissan Versa Note SV
Hello,
How does one remove the rear door panels from a 15 Versa Note SV with automatic windows?
I removed the front ones easily but contrary to instructions there is no torx screw securing the door handle to access the 10 mm bolt behind the door panel.
Thank you.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
There should be a plastic escutcheon in the bottom of the pocket which covers up the torx. Once that's removed you can pull the pocket and switch to reach the 10mm underneath. Then it's just pawls, pull the panel free and disconnect the cables.
15versasv
Thank you so much!
The cover looked liked it was attached to the handle assembly.
Took a small knife to get the cover off and there was the torx screw.
The rest was easy!
VStar650CL
Technical Expert
:dblthumb:
Return to “Versa Technical Discussions”
