zakmartin »
https://forums.nicoclub.com/zakmartin-u136442.html
Tue Dec 09, 2014 3:23 pm
Wow. Just wow. That whole dealership checklist just screams, "We despise our customers and we think they're all idiots."
Do your regular oil changes, check the brakes, bushings, bearings, ball joints and linkages (all very simple for anyone with a jack to do). Change your filters. Check the tread on your tires. Top off the windshield washer fluid. Finally, check your serpentine belt for glazing and cracking and replace if necessary (only do this if you have the right tools and a person to help you out - it's a pain.) You're good to go until you hit 100,000 miles.
If your car is a 2011 with 60K, it's far too early to change the coolant. You can check its condition with an anti-freeze hydrometer (about ten bucks at the local auto parts store). Technically, the CVT should last the life of the vehicle unless something in the transmission breaks, in which case, it will need replacement (and you're warranted for many many years and miles on that).
All the dealership is going to do is hook the car into their Nissan Consult computer and the computer will tell them if the CVT fluid needs flushing, if any weirdness is going on with the ECM, BCM, SRS, ABS, etc. etc. Then they're going to put it on a lift and check out all the rubber bits under the car. If they're GOOD, they'll do a sniffer test to check for exhaust leaks. Now a-days, about 90 percent of the diagnostics are done through the OBD-II port.
I'm only surprised that they didn't include blinker fluid change on that list.
zakmartin on Tue Dec 09, 2014 3:34 pm, edited 1 time in total.
