bucksnort wrote:Revversa
rotors will only warp from extreme heat. Did it get really hot on the dealers lot? Like 1200 degrees?
Actually thats not true. Many cars already have 10-15 miles on them before they even get to the dealership. So 1) Someone could have abused the brakes before you go the car. 2) Could be a factory defect. 3) Could be rust or debris from the car sitting from long periods of time, example, solidified brake dust... 4) Could also be bad hardware in the caliper. If the caliper isnt in contact with the rotor the same all the time, you can warp, or mildly disfigure the rotors pretty quick.
The warrenty on Wear Items is explained as: during proper driving, if a premature failure is found in a wear item, it will be replaced under warrenty. However, Who decides proper driving? Best thing to do is if you buy a new car, dont settle for OEM parts. First things i always replace are: pads, rotors, brake lines, Endlinks, D bushings, Battery ground cable, Exhaust ground Cable, Oil drain plug, and install a transmission drain plug.
Why do i go through all that hassle? Simple, OEM parts are made for casual drivers. I live and work in New York, there is Nothing Casual here. Besides, usually aftermarket parts are better and cheaper then OEM parts.
Now your gonna say a lack of Aftermarket parts for the Versa, Thats not true either, you just gotta know where to look, and what cars have compatable parts. Slotted rotors, Hawk Pads, earls stainless steel brake lines, Energy suspension endlink and D bushings, Fram oil plug, And some high grade Audio wire is all you need for that type of work.
