There seems to be a general consensus that it is OK to go staggered on AWD if the difference on the rolling diameter between the front and rear is 1% or less.wideopn11 wrote:Best not to run a staggered setup on AWD.
^this. It's scary but can easily be done when researched and rolling diameter is well within the 5% mark. But 10.5 should be fine. I run 10.5 +27 on front and rear of my M56.SwissCheeseHead wrote:There seems to be a general consensus that it is OK to go staggered on AWD if the difference on the rolling diameter between the front and rear is 1% or less.wideopn11 wrote:Best not to run a staggered setup on AWD.
