junkyardogb13 »
https://forums.nicoclub.com/junkyardogb13-u69075.html
Sun Jun 24, 2007 8:46 pm
i swapped a sr20 into my sentra91.the motor is installed and will turn over and fires with starter fluid.the problem is that im not getting any power to the e.c.m.,and the fuel pump doesnt come on when you turn the key.do ineed to swap out the entire under dash harness that runs from under drivers side of where the engine harness connects to the three plugs mounted on body.the motor is from 92 93 g20 low port the throttle body is under the intake manifold. i have two different e.c.m.s one from 91b13ser and other from the g20.the fuel pump is good also.PLEASE HELP
Modified by junkyardogb13 at 9:15 PM 6/25/2007
