08 versa sl MT
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
viet510racer
Car: 08 Nissan Versa SL
was wondering if anyone else noticed a rough clicky shift into a gear with their gearbox?? i noticed my 2nd gear is the roughest, all the other gears are a little smoother. any ideas on how to fix this?
P.s. i only notice this when its first start up, once engine is warmed up and such the problem goes away.
Modified by viet510racer at 6:11 PM 9/15/2008
Visaversa
Car: 2008 Nissan Versa S Sedan
Nothing yet but only have 5400 miles. Its sounding like your synchros are not doing their job. Take it to the dealer.
motoguy128
Car: 2007 Nissan Versa S - 6 Speed
1st to 2nd is the largest jump in gear ratio and is often the roughest on any vehicle. It possible there is an issue however. The only way to know if to drive another MT Versa.
Has is gotten worse since you bought it? Are you getting the clutch pedal most of the way in before moving the lever and waiting to release the clutch until after it's in gear engaged. With the RPM's hanging form the electronic throttle, you defintely need the clutch since the RPM's are sometiems a little high for it to slide into gear smoothly clutchless.
viet510racer
motoguy128 wrote:1st to 2nd is the largest jump in gear ratio and is often the roughest on any vehicle. It possible there is an issue however. The only way to know if to drive another MT Versa.
yea it has gotten worse since i've had the car. with 5xxx miles on it. i guess im bringin it to the dealer soon. p.s. what other problems will occur if i just leave it the way it is?? just out of curiousity
kcourtad
Car: 2007 Nissan Versa SL Sedan
mine still does that when i get in to 2nd gear... i just learned to live with it now... but it doesnt do it anymore...
antebellon
Car: VERSA
Mine seems to have the same problem sometimes. Does it matter in the long run?
Return to “Versa Technical Discussions”
