My car has the same issue and i took it to the dealership and they said they didn't find or replicate the noise. I noticed that it usually does it when the car is cold and the AC is on, thats when it does it the most.yellowspecv918 wrote:noise happens when i crank the car. the noise sounds like a grind, kinda like when u dnt have your car in gear all the way and it makes a grind/scratchy sound. its not as deep or long. just a quick scratch and then it goes away and my speedometer needles move side to side and does its usual start up. idles fine and drives fine. does not happen consistently, but intermittent. any ideas? thanks alot! o...and its at the dealership getting checked out rite now. just thto i get a couple of ideas before i get a phone call. haha
Yes it sounds like thatdjtorello wrote:is it the same noise as if you tried to crank it over while the engine is already on?
The specv requires premium gas while the se-r does not.yellowspecv918 wrote:it doesn't do it anymore for me and the dealership couldn't get it to happen either. i remember it happening one time after, and that was when i was low on gas. i had just one bar left. fyi for all spec v's...its best to use pure 91 octane premium gas for our cars.
