07 Sentra clutch safety switch for remote starter problem solved!!!!
bundy26
Car: 2011 Buick Regal turbo
I`m going to say f*ck the warranty by doing this, the wire that goes to the starter from the ignition key cylinder displays 12v when I turn the key but the car not starting because I don`t press the clutch, so what I`m going to do is tap a wire directly from the ignition key cylinder to the starter and car will start without pressing the clutch. I would appreciate opinions about this since this is the only way to bypass the clutch safety switch that I found possible. Thanks for everyones help on this problem.
gotak
Car: 2007 Sentra SE-R
I don't know exactly what you want to do but incorrect messing around with the electrics is a prime cause for car fires.
