Since the car is unibody, I lift it off of the pinch weld on the front and rear.gotak wrote:I got the FSM but I am not 100% clear where they say the lift points and jack stand points are.
From the looks of it the jack stands should go where the emergency scissor jack goes right? But for the garage jack points I am not sure where that's suppose to be. Can someone take some photos and point them out?
Thanks!
If you have jack stands that have a recessed groove you shouldn't. I've lifted Muranos up by the welds with the feet of my lift up at work and nothing bends.gotak wrote:If i use the jack stands on the pinch welds I risk bending them no? Since all that weight is sitting on that pinched lip.
That canister is the charcoal cannister, part of your EVAP system. I wouldn't go off the torsion beam. Go right under frame of the car and you should be fine.gotak wrote:No grove...
So if i turn the stands side ways so it's not on the welds will it hold?
The rear jack point is it that block that sticks down behind the torsion beam? I think that's where the guy who changed me to the winter wheels jacked the car up on. But I want to be sure that's the point before I use it. Cause in the FSM it says something about a canister being near that factory jack point.
The front jack point is the middle of the black subframe/suspension frame right?
I would honestly use the welds...you will be ok.gotak wrote:
See that silver block there in the upper right hand corner, not my car, that's where they jacked the car before is that a safe jack point?
And that's the front subframe right? And is that a safe point to use?
You could also try putting 2x4's or some piece of wood under the weld if you're afraid of it crushing.gotak wrote:Well I am going to look into stands with the groove cause the idea of the edges on 4 welds on stands just sounds like it can slip and fall off. But I guess I can just use the jack points they used before for the jacking part since it didn't so anything to the car.
