C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Mon Jan 28, 2008 10:23 am
Nope. The OE plugs are double platinum NGKs. So replacing them with the same would only provide as much performance as when they were new. Iridium plugs can provide a slight increase in performance at best, but currently, NGK doesn't offer a double iridium plug or a plug with an iridium center and platinum ground electrode (they are available outside the US however), which means they wouldn't last as long.
A potentially better plug might be in a particular liine of Denso iridiums. Currently, Denso has a center iridium/platinum ground plug here in the states, but it is not really designed to perform much better than the current platinums (except for longer wear). But they have a performance line of iridiums that run an ultra-fine wire center electrode. Unfortunately, in the states, they use only a iridium center electrode, while there are versions of this plug with platinum ground electrodes available outside the US. Essentially, such a plug wouldd have benefits of running a smaller center electrode, but have a reasonable lifespan in vehicles using coil packs.
