04 Q45 BCM location
Sjklontz
Car: '04 Infiniti Q45
Every time I research the body control module on my car I come up with one type in a metal box with metal bracket. But the manual I looked at on this site shows the BCM location is to the left kick panel on the drivers floor. I opened it up and found a module. That is plastic and does not resemble the one that I ordered. I can find nothing like this online. Is this the correct location for the body control module?
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
ENGINE CONTROL MODULE is Lookup Code 22611 in the diagram.
Sjklontz
Then would you be able to link me a body control module for sale for this model? I cant seem to find one.
Rogue One
2022 Honda Pilot SE
Go to https://www.infinitipartsdeal.com and put in your VIN. You're going to need to know your car's production date to get the correct model number. Once you've got the correct model number you can check eBay or try a salvage yard.
EdBwoy
Could you post a picture of what you bought? It might also have a part number that you can look up.
You seem to have gone to the correct location for the BCM in your car. Left kick panel, under fuse box.
2002-q45-major-fuses-relays-and-modules ... 22905.html
ricare33
Car: Nissan Note
Rogue One wrote:
Fri Jul 03, 2020 6:26 pm
information about what is encrypted in each digit of your VIN number https://carmotospecs.com/vin/infiniti/
