Tried the button inside....nothing.
Flipped the switch in the glove box (reset procedure)....nothing.
Called Infiniti and they told me it was probably the trunk actuator and told me how to open the trunk by dropping the back seat with the red pull string.
Googled and others had same issue, but cause was broken wires in the harness.
So, I checked and this is my problem....three broken wires (dark green, light green, black)....probably explains why my trunk light doesn't work....
There is very little slack in the wires and it's almost impossible to get to the wires that are down in the boot.
I'm think about slicing the boot open to get to the wires so that I can fix them.
Anybody know of a better way than slicing the boot???
Going to call Infiniti to see what they would change to replace that harness.
