04 350z Gray built motor APS twin GT3071r turbo
Nissan 350z / Nissan 370z classified ads, parts and accessories
Mbz
Car: 04 350z built motor APS TT
Postby Mbz » Sun Mar 23, 2014 9:51 am
Clean/ lien free VIN=JN1AZ34E14T060586
For sale dyno tuned 600^whp 04 350z around 44.5k miles on the od only 5k on engine build clutch and turbos. Engine build & tuned by Grd of Chicago in 2013 the APS ballbearing turbos were converted from GT2871r to larger GT3071r by Blouch Turbo. The turbos boost from around 2800rpm all the way to redline strong. Asking $25k autotrader ad: http://m.autotrader.com/cars-for-sale/v ... &zip=53406
Email questions to [email protected]
List of work:
Oem gaskets/ waterpump/ oil pump etc...
Oem Crankshaft
Cosworth Main and journal bearings
CP pistons w/ oversized 8:5:1 comp.
Eagle Rods
Fresh rebuilt heads
Ferrea 1+mm oversize valves
SGP stiffer Valve springs
ARP main & head studs
SGP racing full fuel return
Deatchswerks 800cc injectors
aeromotive fpr
APS twin turbo tuner kit(turbos rebuilt by Blouch GT3071R trim)
APS tall boy intake manifold
APS Turbo back Exhaust
Forge wastegate actuators(red springs)
Koyo Radiator
Mishimoto 68• c thermostat
Greddy coolant breather tank
Injected Performance oil catch/ pc breather
Stillen engine dampner
Uprev tune
Uprev turbo MAF sensor
Apexi boost controller
Prosport boost & air/fuel gauges
JL audio Amps/Boston Acoustic speakers/dyna matted insulated interior
ATS carbonetics Twin disc clutch
CD009 transmission
Nismo rear end
Tein coilovers
Whiteline Front and rear Adj. Sway bars
Whiteline Adj. Sway bar endlinks
Adj. front & rear camber arms
Spl lower control solid spherical bushings
Brembo brakes
Volk LE-37 wheels 19X 8.5 front 10.5 rear
BFG KDW Tires Front (80%tread)
TOYO R888 295/30/19 Rear(brand new)
Return to “350z / 370z Classifieds”
