'03 M45 Headlight...
Strongbad
I was recently hit in a parking lot in my M. They hit me right at the front end of the passenger side fender and knocked off my bumper cover. At the same time, they apparently pushed the headlight over as well. When it did, it snapped the two plastic mounting tabs at the top of the headlight.
Now the body shop is saying I may need a new headlight, despite the fact that my old one is still working fine. Xenon's, blinkers, everything. Still works fine. Only thing wrong is the mounting tabs are broken.
Is there a way to fix this? Epoxy?
Anybody experience anything similar?
Dnight07
Car: s14
plastic weld worked for me my friend also used it works wonders also if you fiberglass it and re drill the hole will last a lot longer with no problem..
Strongbad
Dnight07 wrote:plastic weld worked for me my friend also used it works wonders also if you fiberglass it and re drill the hole will last a lot longer with no problem..
Those both sound like great options. Thanks!
Is this the stuff you used?
http://www.hobbylinc.com/htm/dev/devs-220.htm
