PapaSmurf2k3 »
https://forums.nicoclub.com/papasmurf2k3-u3044.html
Sat Dec 25, 2010 7:54 pm
Welcome to NICO!!!
I'm having a little trouble understanding exactly everything you're saying, your typing is a little off, but I'll try and piece it together.
Did it flood out just once, or does it do it fairly often? Pull the oil dipstick and smell the oil. If it smells like gasoline, you need to change it immediately. Gas will ruin the lubrication of oil when it gets mixed with it.
Try and hold the gas pedal to the floor when cranking to "blow out" the fuel that is in the cylinders. Keeping your foot down will let more air into the engine, which should help keep the air/fuel ratios a little more in check.
The only thing I can really think of would be 1: The ECU somehow went bad (seems unlikely), or 2: The coolant temp sensor is telling the ECU to dump fuel.
