i think my clock light has burnt out. does this pry out of the dash, or do i need to remove the bezel around the navi? is there a special bulb, or can i get this at radio shack?
also, it appears as if there is supposed to be a light on the driver's door panel just above the window switches. if so, that too is burnt out. do i have to remove the whole door panel to get to this, or does this also "pry" out for easy replacement.
any help would be much appreciated.
also, i am looking for a f.s.m. so i can learn how to do things for myself. as you may know, these cars are too nice to "experiment" with by trying to remove clips and trim panels without knowing the proper procedure.
thank you in advance to anyone who is willing to share their knowledge.
[email protected]
