Md is right, 6-point is de rigueur. A combination of torque and impact will often bust fasteners that won't break with torque alone. Put about a 3-foot plumbing pipe over the end of your 18" breaker and have an assistant put moderate force on it while you rap the pipe with a hand sledge. Some impact will also help assure that the sleeve breaks free from the bolt without spinning out. Heat on the nut may also help, but don't directly heat the bolt, that will make the rubber more likely to give up.mdmellott wrote: ↑Sun Sep 19, 2021 9:06 amUsing a six-point socket will prevent stripping the nut. Twelve-point sockets give you more rotational angle approaches for engaging a breaker bar put they tend to strip nuts when the nuts are badly seized and rusted onto the bolts. An 18" breaker bar is barely long enough to get the torque you need to break these rusted nuts free. A 24" breaker bar would be work better.
PB Blaster Penetrating Catalyst works best on rusted bolts. It's not a lubricant. It has one job and that is to penetrate deep into rusted fastener joints and dissolve the rust to free up the connection. I used it once on a seemingly hopeless corroded door lock on my old '91 Pathfinder. Road salt and years of not being able to use the lock with my key, the tumblers and every other piece of the lock became one rusted fossil-like waste case. I removed the lock and soaked it in PB Blaster for at least 4 hours before I was able to get a slight amount of movement in the lock mechanism. Soaking overnight, I was able to completely free up every tiny piece in that lock, take it all apart, clean it up, and it worked for many years afterwards, applying a lubricant when it was all back together to keep it that way.
Thanks.The Grand Pooh-Bah wrote: ↑Tue Sep 28, 2021 6:08 pmI had the same problem. I purchased a better air impact 1190 ft. lbs of torque from Harbor Freight. Item 62891. It made short work of all the control arm nuts.
