I was looking at my fuses and noticed this was missing.
I looked into it and it says that it's the electronic traction system. Seems pretty important. Any idea why it would be missing?
Post by Fosty » https://forums.nicoclub.com/fosty-u284801.html Sun Mar 27, 2022 10:49 am
Post by mdmellott » https://forums.nicoclub.com/mdmellott-u292054.html Sun Mar 27, 2022 2:10 pm
I suspect your 2WD model never had it. The Automatic 4WD models of the QX4 have traction control so the common relay/fuse block has a fuse position for that. If yours never had a fuse there, just like my 4WD Pathfinder never did, there won't be a wire connection on one leg of the fuse slot. As you can see on mine, in the picture below, there is a connector on the right side leg of the fuse slot but nothing on the left side.
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
