'00 Q45 AE performance recommendations
Sapofeo
Car: 00 Infiniti Q45 AE
93 Toyota MR2 Turbo
03 Ford Excursion V10
14 FiST
I'm now 8 months into this daily driver project and financially I'm passed the point of no return. Suspension/wheels/tires etc. all done properly. I'm now facing a small head gasket leak and I'm struggling to find a viable upgrade path (if there even is one).
An engine swap to an older vh45de seems drastic for not much gain. Is just swapping the internals a better option? I don't see vh45de cranks available anywhere. Is it best to just rebuild the motor as-is and get some mild head work done while the heads are out? Is a basic I/H/E/flash the best route? I'm looking more for a long term cruiser than any real performance setup.
What is the community accepted upgrade path for modest gains? Budget <$3k-ish
Thanks in advance
Sapo
Ludeaem
Car: 2000 Infiniti Q45 AE
If it were me i'd just take the heads off and get the head gasket replaced. For performance I don't think much will be can be done short of boost that would be worth it.
Skibane
Car: 2000 Q45 AE 110K
Junkyard GM LS engine.
You could spend an entire lifetime exploring all the cheap power upgrades.
:biggrin:
MowgliCSM
Car: 99 Q45t, 07 S550, 89 Mitsu Mirage Turbo.
2JZ swap or if you have the cash and want to keep it in the family, an RB26.
Ludeaem
Did you guys read? Budget is less than 3k. Almost nothing is going to happen with that budget even assuming he is doing the work himself. Most items are going to be custom $$$
MowgliCSM
I missed the budget. If all the work will be done themselves, then an LS is the easiest/cheapest option. Buy a junkyard motor from a Silverado and slap a cheap turbo on it. I bet you could do that for around 3k. Might not be pretty, but will be easier than trying to turbo the VH and allows infinite options down the road.
Sapofeo
93 Toyota MR2 Turbo
14 FiST
I decided to just milk the luxo-barge as a daily for as long as possible. So far so good. I'm lucky to have other projects to tinker with instead for the speed itch.
BadQ45t
Car: '21 Nissan Leaf SL Plus (wife's car)
'05 Nissan X-Terra S 4x4
'97 Infiniti Q45t SOLD! Miss the old girl
'84 Nissan 300ZX (Original Owner)
'16 Mercedes Benz S550e V8 Power & 35 MPG
i owned my 97' for 19 years, did coilovers, big wheels/sticky tires but past trying a little higher flow exhaust there are no upgrade paths so your choosing wisely. Finally did my upgrade to S550 Plug-in hybrid, over 430HP and 470 lbs off torque....but it was a little more than 3k budget :woot:
